Help!! Need Adaptor plate to bolt a fm146 to gm 350!!
Ridgely, Tn
;brownbag;Yes i no im falling away from my strong ford heritage here but i have jus craked the block on my 4.0 in my 89 bronco 2. . . ( got drunk an stopped up the radiator:( ) . . . im short on funds an i just happen to have a 350 with less than 50k miles on it that came out of a 69 yenko a guy wrecked. . . does anyone know of a company ( or jus any person for that mater) that makes an adaptor plate for the fm146 5 speed to a sbc???
you could try advanced adapters, but i doubt any company makes one.
my uncle once put a john deere engine in a studabaker truck using a rim to make a bell housing to bolt up the stock trans
An fm146 mated to a SBC???????
:icon_confused:
I'm suprised it held up behind the 4.0
Whatever you choose to go with, this is not an easy or staight forward swap....and certainly not going to be cheaper than finding a junkyard 4.0.......
or a junkyard 700R4 to put behind the 350... That 350 is going to eat the fm146 alive. There a ton of different transmissions that were used in chevy trucks behind the small block bolt pattern and I'm sure you could pick up a good one dirt cheap from any yard near you.
yeah i no it . . .but if i go with a gm 4 wheel drive tranny then i gotta go thru the process of findin another t case, drive shafts an axles:bawling:
Help!! You need a head scan!!
The FM146 doesn't live for shit behind a 2.9 let alone a 350. It will be a LOT cheaper in the long run to find another 4.0 and for your tranny's sake, a M5OD before you kill that mitsu.
Sell the 350 and buy another 4.0.
Yeah, don't even bother with the 350 hooked up to a FM146. Get another 4.0L, it'll probably be cheaper when it's all said and done. And get an M5OD while you're at it.
