Help me find vacuum leak?
Mike1919
Fresno
As the title says i cannot for the lufe of me find a vacuum leak. I have a high idle, right between 1000-1200 and the second i turn the engine off, if i remove a vacuum line from the plenum, its already lost vacuum. I tried the starting fluid trick as well as the unlit propane torch trick. I went all around thd throttle body, all along tge intake vasket as well as the plenum with an unlit torch. I hit every connection and followed the vacuum lines down to the next connection and got nothing. I also tried the plenum gasket and got no signs of a leak. Correct me if I'm wrong but the plenum should hold vacuum after the engine is shut off right? I dont know where else to look. Also my cruise control doesn't work, but i unplugged the line from the tree and capped it off to eliminate that possibility, thanks
Well for anyone who was wondering it was a bad throttle body gasket.
Surprised that didn't show up with the starting fluid.
Well it was good Saturday, i pulled codes and code 411 was gona. Now its Monday morning and it's back to a 1200 rpm idle. Kind of puts a damper on things. I called my local mechanic and they said its $120 for them to diagnose it. I'm now thinking that would be better instead of taking guesses.
Also id like to mention that unplugging the new idle air bypass valve while running does nothing. Nothing at all
Okay well i got it in the shop and tgey said someone has tampered with the throttle body and drilled a hole in the butterfly valve thats not supposed to be there. I think thats the problem
Well I'm going to the junkyard this weekend to get a throttle body, can i grab one off of a explorer with the 4.0? Also mine does not have an egr system. Are the throttle bodies different for the trucks with a 4.0 and egr compared to one without an egr valve. Thanks
