HELP HELP HELP any ford techs out there?
97Tank
Pittsburgh
Well about two weeks ago my truck started missing...i Went and got it diagnosed and it said it was the cam sensor...well i found TDC and replaced the sensor...the synchronizer was bad so i went through the steps to replace that...still runs HORRIBLY NO POWER WHATSOEVER...checked the cat and THATS not it either! Could it be a timing chain? anyone any input i neeeeeed it
THANK YOU!
Ed
Start simple
THANK YOU!
Ed
Find an old style timing light and make sure all cylinders are firing.
Any check engine codes?
Can you check #1 cylinder valves for full closed at TDC?
If you didn't have the cam tool it could still be off. I wouls start with basics as mentioned above, also double check plugs and wires.
You didnt find TDC on the exhaust stroke did you?
I know with a distributor you can do that and then it wont run (most say 180 deg out) but i dont know if its possible on a DIS system. It might be but the computer might be able to compensate enough to make it run?
later,
Dustin
nope had tdc on compression every time i realigned it also replaced all plugs and wires still misses horribly
