Cyx-Ryan
- Jul 2, 2012
- Automatic
1997 Ford Ranger Splash 2WD 4.0L 142k Miles
So let's start off with ABS light... Last year a spring broke in my drum brake and was making a lot of noise when you drove it. My dad replaced the drum brakes and everything inside the drum. After he was done I noticed the ABS light was on and has not went off since. Any idea what would cause this issue for the light to stay on?
Brake light, a few months ago the brake light came on and has not went off. Usually when we park we will push the E Brake down because sometimes my shifter does not go into park all the way and heard was a screw that was loose so I use the E Brake to keep it from rolling. I always release it and make sure it's up all the way. My brake fluid is fine so i'm not sure if this has anything to do with the ABS light being on for some time now.
Engine codes: right now my truck keeps throwing codes saying bank 1 is to lean and bank 2 is to lean. Not sure what the codes # off the top of my head but can keep them off the truck later today. I took it to autozone and they scanned my computer and told me that it was the 02 sensors that are causing it.
I also noticed that my truck jerks a little bit like its misfiring but doesn't throw off any codes. Sometimes when I tap on the gas my truck will also stall out. The plugs/wires were recently replaced is 2012 so im not sure if its that or something else.
Any help would be greatly appreciated! <3
