hntr45
- Sep 27, 2014
Hey guys, so I have been having issues with my HVAC. woohoo.... anyways I know the problem must be vacuum related but I can't seem to figure out what is actually wrong. I would assume that the vacuum reservoir under the hood is fine because i do get vacuum into the firewall. From there it goes into the vacuum selector switch (controls ac, floor, vent, defrost, etc.) after that I have no clue what to check. I recently replaced the vacuum selector switch also, but it did not fix it. I also noticed the motor directly behind the glove box is not opening when it should. I pulled the white hose off of it and checked the vacuum, and there is very little vacuum. I'm not sure if that helps at all, but I want to be specific as possible because I don't have too much experience with vacuum lines.
