- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
Hi gang. Have a further question to this post.
I've used the adjuster screw all the way and beams are still too low. I replaced the rear springs and the truck sits a little high in back so the beams still point at the gophers now. (No - the answer isn't bigger springs on the front)
Do the screws in back of the light frame allow for more adjustment of the lamp? Has anyone else run into this?
I'm not so familair with the "square" rangers but if it's like the 1993-1997 ones, there are 3 mounts per light, two of which are adjustable. One is on an edge, one is on a corner; you adjust the corner one first (as it moves in both the x and y axis diagonally) and once your up/down is set, you adjust the edge mount to get the left-right set (as the corner also changed the left-right).
If you're out of adjustment, either you are riding really, really high in the back (sorry, you'll have to fab something to make it work in that case) or your lights are not mounted right... Or you're not adjusting the lights correctly. Unless you want to blind people (if so,
