Dweano
Well I feel like I've made way too many threads about my attempt at putting on headers project. I finally thought I was in the clear tho. All the old bolts were out, all the rusted junk was dealt with. The headers were sandblasted and painted. Ready to go in. So i start tightening the bolts on my new headers (new bolts). And bam...one snaps off in the head...
...yup a new bolt sheared off in the center of the bolt. The worst part was, it wasn't even tight. The header wasn't even snug against the heads let alone tight. So now I have whats been reduced to a threaded rod in my head, thats in there tight! I thought oh there tight, friction fit it'll hopefully stay in there and not cause leaks...then it breaks before it even snugs up the header... frick. I am definitely getting new bolts now. So my question is, what size bolts do I get? 96 4.0L OHV, pacesetter headers (I know, I know...lesson learned). And also what is the strongest ones I can get without having to get something specially made? I don't know much about bolts and stuff, I assuming I have to get the right threading and size and everything. Second question...how in the hell am I going to fix this problem? Theres maybe 2mm sticking out...tops..I'm thinking i can maybe weld a nut onto that? I'm tempted to send a very angry letter to pacesetter, you'd think the old 13 year old, hot and cold 10000 times bolts would break, but not the new bolts provided. And you'd also think that they would be the right size because they were turning in hard! Hence the breakage I guess.
