TTurner161
- Dec 23, 2008
- Automatic
Rumor has it the 2.3 (and the 2.5 if its based upon the same design) is next to impossible to line up timing-wise. Always about a half-tooth off. Not sure why... I've heard people say just turn the cam sproket 360 degrees to fix it, but wouldn't that just put the cam back in exactly the same place?
Yeah they dont line up quite perfectly like you said, I guess as long as its as close as you can get it.
There is nothing whatsoever difficult about timing the 2.3/2.5 Lima engines. The only RBV engine I've heard of being a problem is the SOHC 4.0.
Well its not difficult, its just the marks aren't all to accurate. I mean the timing marks are on a plastic (which means flexible) cover afterall.
BTW guys I got it all back together and put new fuel injectors in, which ended up being the issue from the start. This truck has never ran this good/smooth.
