Hazard lights not working correctly
bryanb
Western Montana
1989 Ranger.
Hazard lights work oddly. use replaced both flasher switches in the fuse panel. Makes no difference in problem.
Hitting the hazard button, and they work fine, but if I apply the brake pedal, they stop, and are only on solid (not blinking) like a brake light.
Is that normal, or something wrong?
If the stop and turn signals share the same bulb filament... it's normal.
Can confirm, you are describing normal operation, there is nothing wrong
