Has anyone put an inline 6 in a Ranger?
Only reason why they put V-8's in trucks and cars now a days is to save space, lighten stuff up and everybody is so hell driven on the thought of a V-8.
Like people may ask why did you buy a ranger with a 3.0? Why not get 4.0? Or why not 4wd? Because it was your choice.
Lol, a 4.6, 5.4, 6.8 and PSD save space over the 300.... I dont think so...
They are hell bent on a V8 because they make more power.
For me, its simple... They didnt make a supercab ranger with a 2.3 when I bought mine, and I couldnt afford a 4.0 or a 4x4, for what it is, my 3.0 gets up and goes pretty well, before you talk smack about it, you should try a late model one. :D
Not with the electric 4wd I wont. Screw that IFS too. If I get a late model one, it wont look factory when I'm done. And all I see in the v-6 forum is people with the 3.0 with non-stop problems. I'll take a 2.9 over the 3.slow anyday.
Ive had both....
My 3.0 is far better than a 2.9....
100K and not one problem yet...
All of the engines you listed are shorter than the 300 six. In case you haven't noticed, every vehicle made today has a shorter engine compartment. That was the "space" saved in dropping the 300. This includes the Ranger. There's hardly room for the length of a 302 in one, let alone the 300.
Ill have to check that out.....
Your going to believe what you want, so will I. Fact of the matter is argueing is worthless, fun, but worthless. Ive seen what a 300 will do, seen what a 302 will do, was waaay more impressed with the 300.
For general running around, drag racing, and MPG, the 302 is better.
If your going to use the thing like a truck, the 300 cant be beat.
later,
Dustin
actually the overall engine compartments are larger in the newer ranger...the fullsize trucks just have the windshield sitting over them making them more like a van with no doghouse to work with on the backside....:icon_confused:
this modern setup is .....just stupid to me.:dunno: but its the way it is now...well for now anyway. i feel sorry for the dealer guys that have to work on them.
for example the difference in putting glowplugs in a 96 psd pickup and a 99 psd pickup is huge time wise....it only takes me about 1/2 hr 45 min longer to do a e seies psd glowplugs then a modern sd....:icon_surprised: the cummins is a bit longer then the 300, and the psd package takes up more space then the 300 in my e series.
anyway the good ol 300 ford commentaries are always hystericle as well.
the one ton and dump truck uses are always good fall backs, but not in the way it is always sold.
for what they are (300 six) they do well in the later efi version.. but on direct comparitives they are just f-ing gay. since it is falling back on alot of real man tow stuff as it being a superior engine i would like to look at that a bit....
stock for stock in the carb days they are above par with a low 302 with the lug advantage being to the 300 for obvious reasons.
the 302 most certainly did power 1 ton trucks...those of us that remember the malaize period....gas lines...... and the 80's recession following it.... know for sure 1 tons had a wide selection of engines. one thing that recession did was streamline engine selections....especially in the 1 ton market.
the reason the 302 dropped was redundancy.... like admitted already there is a decent advantage on the low rpm end with the 300 in real power on the WHOLE curve..quite the stroke there..in any event call ford, go to the ford truck plant and ask on the tour. theres alot of history there.
hell 79-81 or so there was the k and b 300's the g 302, h 5.8....460 and two 400's in the trucks and i think the e series had a few more. thats on my f service manuals....power on all are dismal at best. but that is too many engines to handle......then add in the lpg versions ect....alot of waste manufacturing wise...
how anyone can consider 265 pounds of torque at 2000 rpm a supreme towing setup with only 120 hp backing it up at that peak is past my capacity to reason with. but for light use say up to 7 k its definatly just fine to get the job done..better then most time period 302's. this is up to say 93...the following years seen the 302 come up to stang specs power wise which put the 302 at par with the 300....8-12 pounds less torque at the 2000 rpm doesnt make the 302 inferior at that point and it just gets satronger from there. but it sure as hell wasnt going in the 1 ton line either..and the 300 was shitcanned too because its was useless for modern needs as a 302 would be in a 1 ton...
the aod/4r70 and the c4 all came behind the 300 six...seems most people say contrary....in the big trucks the e40d was behind all the engines depending on how packaged. in a 1 ton its either a e4 or c6 for an auto.
back to he reality of the topic. this is a fuggin rbv forum.
a carb 300 setup will easily fit in a ranger.
the even bigger reality is these engines are extinct in regular production vehicles....300,302,351,460.
finding low mile units is hard to do.
so generally speaking basic rebuilding will be in order for best performance and reliability.
in this light the 300 is an awesome engine to build...its different and can be built with the same budget to provide similar numbers for streetable daily driver applications. a turbo inline 6 or turbo 2.3 offer as much fun as anything.
in that light it is the reason you will see me often suggest the ls engines for power swaps...sure its gm but dollar for dollar they just are hard to beat.
while personally i prefer v8's and wouldnt have a stock inline 300 over a stock type gt40 302/351...... i do encourage guys that want something different.
in the end....budget wise most guys will do better with oem v8 parts for a rbv engine swap. and generally speaking its all about budget.
this is too long already to go over all the other horseshit in this thread...so i am out for now.
regular truck engines rusty has the point....i have owned enough 300's to know that. compared to my last 302 which is pretty much oem stuff, a 300 would look less and definatly be out performed all things being equal.
That was the most most reasonable post in this thread...:icon_cheers:
reasonable from a guy that has a daily driver ranger with a 6.5 diesel that has been known to roll down the road on 44 inch tires to get ass hat buddies out of places they dont belong.
he he he....
you have to remember just because rusty might drive a chevy truck....he still bleeds ford blue when he busts his knuckles....the ol boy just cant help himself
aint that right rusty:thefinger:
Yes sir.
Im just a fan of the 300, always have been.
I dislike the 302 with a passion.
later,
Dustin
That may be true in the newer Rangers, but the 84-94's ? No way. The 302 has hardly room to clear the radiator if you try to use the O.E unit. No way a 300 will clear unless you move the radiator to the front of the core support. As I recall someone here did a 300 swap and had to remove half the dash and firewall to fit it.
yes...i remember that...i was tempted to go to his house and beat him with a stick as well:D.....
actually i know mark, he is a great guy.....he was real green then just finishing college, but his skills surpass mine now. he would be the first to tell you he can get it done, and likely do alot nicer job then myself, and i know i can do it. interesting note with him iirc is his wife is actually in engineering at cummins as well...
but theres many others that have done it without hacking the firewall. it isnt theory its been done many times. two setups in my club alone. mark and tony. i was actually interested in doing one with rusty. the attempt mark made actually ended up in tonys rig iirc..:icon_confused:
but theres alot to it like you say, and as always comprimises to be made...in a low 2wd it would be a bitch. in a 4x4..with say a body lift and sas its cake.
i pretty much put the radiator up to the grille whenever i can in swaps, but some dont like that.:dunno:
looks arent a top priority for me.
i have been thinking on putting a 4.0 HO in my ranger because i own it its payed for and it works good just the jeep around the motor is breaking in half...got the tools to do the work. I am just not sure on what kind of problems i will encounter by doing this.
