Quill
- Sep 28, 2007
- 88 Bronco II, 8
The 89 Ranger I bought is hard starting. You can only do short bursts with the starter to start it. If you try to keep cranking you will just run down the battery and eventually ruin the starter. There are no codes showing. The previous owner gave up on it. He put a lot of parts in it including the wrong ECU. I had a mechanic who knows a whole lot more check through everything. Tested everything. He is the one to figure out the ECU and starting it with short burst of the starter. Any ideas why it does this and how to get it work normally?
