James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Another non-Ranger question.
I'm almost done prep in the mud room. It's 11.5" concrete tiles. The tiles were red or they were painted red at some point (some red paint remains otherwise they are red-pink). Then lino was glued over them. Then carpet was glued over that. I'm almost done getting all the old stuff off, and since the tiles aren't very consistent appearance I'm going to paint them brick red (like the original(?) paint) and likely I put that gritty stuff (really works) in the paint on the ones near the door. It will look way better.
Here's the question. After I paint, I need to re-grout. I experimented with some grouts I have. To me they seem to have no strength at all. Given they aren't holding the tiles, but it has to not just flake out. I know there's sanded, unsanded, etc... but they are supposed to have some kind of binder, right? I have stuff I add to sakrete when I patch the basement walls. I'm wondering what is it about the grout I'm not doing right? It just seems to me like it has to have some hold power.
I'd paint, then grout, then seal the grout. Seems straightforward, but I don't want to do the grouting then have the stuff immediately start coming out. House was built 1920.
I'm going to get Goo-gone they say that works on lino glue. Alcohol sort of works. You see there is the last of the remaining lino/carpet/glue, this is the worst, rest is done. Heat gun didn't seem to do much. I been chipping away at this like forever and ready to put it to bed. You see it every time you come in/out so it's worth prettying it up. Was using lacquer thinner before, but, it's expensive, and I don't like working around it.
