Grease for From axle reassemble
welderman85
I'm putting my Dana 35 back together and am looking for the best type of grease to use on the hubs and bearings. Thank you
Hightemp disc bearing grease for the bearings and for the manual hubs make sure they are very clean and just get them a little wet with atf.
The hubs should have a very light film of grease on all their parts, but definitely do not pack them full of grease or they won't work right.
×2, a good high-temp lithium-base disc-brake wheel bearing grease is fine. I've used Sta-Lube and Castrol greases before, and stuff in a blue can called "Peak High-Temp Red Grease" (IIRC) currently.
