RangerDanger
- Sep 11, 2007
- Age
- 42
I found one on a 1990 ranger in the junk yard and got it for $100. Took me 4 hours to pull off but i got it. My 1992 4X4 4.0L (5-speed)Ranger also has a 3" PA body lift as well I got from the yard....
6" lift Springs
All drop Brackets for axel arms and radius arms
All 4 shocks and the drop pitman arm
all hardware
It came with HUGE 6" blocks but i threw those in the garbage. What do you reccomend that i do for the rear suspension? I just have the stock leafs will a full overload spring in it now. Im thinking shakles and a new spring pack? but i dont have very much money.
Am i going to need new brake lines?? front and rear?
Is this Rancho lift any good? It definalty looks like its got its use but shows no cracks or anything in any of the brackets.
Oh and also im thinking instead of the drop brackets for the radius arms it would be better to go with james duff or skyjacker redesigned tubular arms. Which one would you guys recommend and will the james duff arms work with my rancho 6" lift?
6" lift Springs
all hardware
