got a 93 mustang
64 1/2 was the first Production year for the mustang, however it shared a frame with the old thunderbird. which was blazin awesome. Could just be a model mixup, but its kool cuz everything from that timeline I still envy today.
There were many concepts n such before the 64 1/2 came out. :icon_thumby:
OP -
I would find a 87-88 Tbird and yank the motor, and drop it in yours. Give it about 27 psi and you'll be eating 5.0's for lunch.
OP -
I would find a 87-88 Tbird and yank the motor, and drop it in yours. Give it about 27 psi and you'll be eating STOCK 5.0's for lunch.
Fixed :icon_thumby:
Ha! Saw that coming. :thefinger:
I didnt say a 6 spd wouldn't just said you could do it. An N/A 2.3 isn't exactly pointless, but you don't have to have a turbo motor nor a computer to make it turbo. Mine is N/A, and am mostly happy with it. The nearest drag strip is about 2 hrs away so have never taken it. Mine has ended up with a stock 94 ranger header, 2.5 inch pinch turn exhaust, a regular muffler, koni adjustable shoicks struts, rear solid mount upper shock mounts, an 8.8 with 4.10's and a l/s, sn-95 spindles on the front, with sn-95 rotors and 99 dual piston aluminum calipers, srock rear sn-95 brakes with north race car brackets, and yukon axles, sn-95 master cyl, converted to a adjustable prop valve, quick turn steering rack with offset aluminum rack bushings, caster/ camber plates, flamiong river steering shaft, ported upper and lower intakes, cam was degreed to factory specs with an adjustable cam gear, also switched coils from a 4.6 mustang with msd coild and an msd distributoless ignition system. Next in line is my through the floor subframe connectors, torquer box plates, and a aftermarket k member. Mine also has a 93 T-5 spd in it with alum flywheel and a 5.0 clutch from zoom...... like I said i'm happy with it for what it is, I will out run any 5.0 i've come across so far in any turns, but the straights get me, also I still have stock rear arms with new bushings saving up for a 3 arm kit with a watts link, i think they are called watts links anyways.
That's all find and great, but I still don't see how modding an NA 2.3 isn't pointless? Of course you'll outrun a stock 5.0 in the turns if they're on stock suspension lol. I'd be willing to bet your car MIGHT run a 16? IDK, I guess it's all relative, but that would be what I consider pointless.
well all depends on what you wanna do. I run scca, not the strip, most of our courses are no bigger than the wal mart parking lot. Also i'm running in the stock class, until the sub frames and k member. In stock class no turbo's unless it came with it, period, even in the higher classes if you run a turbo you have a 1" rstrictor to run with it..... If you still think an n/a 2.3 is pointless you may need to go watch some mini stocks at the local dirt track....:beer:
Very true when you put it that way. :icon_thumby:
Just don't hear of that too much with fox guys I guess.
Sorry I don't have a digi cam right now. Right now on mine i'm on a hiatous of it, i'm working out of debt.:beer:
