The_Dealer
well i got a vacuum guage and got the idle mixture set with the highest vacuum i could get, but it still "lopes" some at idle. also i got the high speed bleed tuned about right, but im only getting about 13-14mpg's. is that normal? i was getting about 17mpg before the duraspark conversion. i tried to lean out the high speed bleed some but it doesnt have as much power. and didnt really help in gas. when i was trying to get it running right i had a couple of good carb backfires and a small fire (was able to blow it out), could that have messed up my power valve causing bad economy?
also with the cannister style coil do i need to gap my plugs more? it runs fine except at low rpms kinda misses for a while but stops when it gets warmed up. but other then that it runs good
