Goofy fuel pump relay, or???
Justin 3J
Hi, I just purchased a 1994 ranger xlt 4x4 and have been through some apparently well known problems like the rubber caps on the shifter housing and putting a bushing kit on the shift knuckle itself. Other than this I have found the truck very sound and reliable; until last night. I pulled into the gas station and filled up the truck. The first thing I noticed was that the cap was very difficult to remove. After finishing off the filling, I replaced the cap and noticed a good bit of gas on the ground. Finally after starting the truck, it idled around 200 rpm and had no throttle response. I removed the fuel pump relay and put it back in and the truck which completely resolved the issue. My question is what the hell caused this and will it happen every time I fill up?
Goofy? You bought a part at Disney? lol. Well, the spill could be from a checked fill tube. They can cause a leak like the one you described. Another thing about that gas cap....it might not be the right one for the truck. Got a buddy with a Ranger? Put his cap on your truck and see if it fits better. You should not have to almost force a cap to come off.
