MrEvilPirate
- Apr 2, 2017
- Central CT
- My credo
- MAGA!!!
Manual 2002 4.0 ranger 4x4 with 176k miles.
The truck is getting very hard to shift. I push harder than I should to get it into gear at stops. While driving it is hit or miss. Even into 3rd sometimes I have lots of trouble. Once in gear it doesn't pop out or grind. Here is history:
Bought the truck about a year ago, changed tranny, transfer, and both diff fluids. Truck was always a little tough to get into gear, marginally better after fluid change but that may have been in my head.
I'm not losing any clutch fluid based on watching master cylinder res for a couple months now.
I've been driving an old air cooled beetle a lot lately which may be distorting my memory, but the friction point on the pedal is like 1/8" off the floor. I push it down ALL the way to shift, if I let up just an 1/8" it starts to grab. No sign of clutch slipage though.
EDIT - Clutch fluid looks black. Anyone ever hear of an instance where fluid can leak out in the hydrolic system but for whatever reason the resevoir doesn't refill the system? Stuck check valve or something?
If I lightly hold the shifter against the gear I want to enter, after a while (like 5 seconds) it drops in. Sometimes I have to jiggle it a bit. To get into first I now have to go into 4th first then row backwards. Reverse is tough.
I've read lots of stuff about how bad clutch and/or slave cylinder can make it hard to shift. I would think that I'd be loosing fluid if the slave was bad. Not sure what to think about the clutch. I was afraid it slipped today, but roads were wet. I goosed it in first a few times and no slippage.
Anyone think it could just be bad syncros in the tranny? If tranny is bad no harm in driving it into the ground, right? Any ideas? Thanks guys.
