getting fuel cranking over no spark
catfish813
central florida
can someone put me in the right direction my 94 2.3 5spd cranks over gets fuel but no spark.also instead of the two clicks from the fuel pump relays im getting like 10 clicks a sec from eec relay as well as the fpr!
Crank angle sensor the most likely culprit. There is an ohm test so check it before you replace it...
Check battery voltage, fuses, and relays.
are you talking about the crank sensor how do i test it? is there a chance it could be the computer this problem came up after the dfpe sensor plug melted on my header and shorted out im stumped ill check the cps tomorrow i priced it today 160$ thanks for the info
ok had a few things wrong put new cps it started then shut off so pull codes and found that the pcm was bad changed it and new fuel charging wiring harness and now truck is running great with 7/16 maf opening,19lb injectors,cai,cat back 2.5 exhaust with 7inch turn down...
