gears set
spanky50
Law Enforcement
muncie,in
4" rough country
32" cooper STT
Looking for a place to buy gear sets for both front and back? I have a 8.8 rear end and a dana 35 ttb front would like to run same name gears.
This forum has a store with affiliate links for parts. Look for the TRS Store at the top of the page if you are on a computer. If you are on your phone, then you'll have to look through a menu. If they don't have listed what you are looking for, Randy's Ring and Pinion is a good place to go to.
+1 to what Sandman said. I bought mine from Yukon. Felt like I got a good deal.
why is it so hard to find 3.73 reverse rotaion gears. for the front. i can find 4.10 but i dont thank i want to go that low i still drive this on the hi way at 75
I may still have the 3.73 gears that came out of my 93. I'll have to look later or tomorrow and make sure they haven't been turning to rust.
When I bought the gears for my '90 back in the day I used the TRS Store, I think I'm using Nitro gears front and rear...
Depends on what engine and what tire size you're running, I have 4.10's on my '97 with 28" tires and it's a good match but it's a 2.3L, I'd probably go for 3.73's if it was a 4.0L but stick with 4.10 with a 3.0L...
