gearhead's build thread
what you have for a axle
HP d30 from an xj
gonna do custom johnny joint long arms
deaver coils
and so on.. dont even have my axle built yet
before you say why a d30: it'll hold 33's for my dd/ww, it's the right width and bolt pattern to match an 8.8.. i see jeeps wheel d30's a lot. and its stronger than that dang ole d28 ttb. (if you weren't gonna ask-- i sorry for the useless info :D)
38in boggers that i wanna run when i get d44 chromoly shafts with the 760x joint
What gears you planning to run?
Id be careful with that setup... Thats asking to pull a few teeth off the ring and pinion...
Looks like its going to be a clean build :icon_thumby:
HP d30 from an xj
deaver coils
sounds good, the d30 is a good swap if your running 33's IMO so i agree with ya there
i have thick cut 4.56 gears im gonna run, i would go 5.13 or something but i have a 302 sitting in a demo car and a AOD with the shift linkage flipped and its notched for a np205 which i have also, im hoping by keeping the front open it will stay alive but i think once i get the suspension squared away im gonna buy a high pinion and put 35 spline shafts in and have that up my sleve incase the teeth decide to jump ship lol
38's i'd say you're in 1 ton territory, i've seen it done a lot tho. should work out for ya, depends on how mean you are to the skinny pedal! lol
only one way to find out:3gears: i know where theres a 1979 hp dana 60 if i need it,
why do the coils bow like this, the axle is pretty close to centered and the coils look fine when the truck is level, ill take it in for a alignment next week and they can make it spot on (trac bar is adjustable)
[/IMG]
[/IMG]
[/IMG]
[/IMG]
the drive shaft rubs the gas tank skid plate too, havent heard of this happening to any1 so i guess im the first
nope, mine been making "music" for a few years.....:icon_rofl::icon_rofl:
also a few have had them fail, especially the aluminum ones.....
l8r, John
im running the stock pitman arm and i need one that has a little less drop to bring my drag link up a little higher so it matches my trac bar, where can i find one that would bolt up? does and 2WD ranger have a pitman arm with a little less drop? also wonder what is the best way to balance 38's bb's, air soft bb's, or ive even heard of antifreze or buy bags of equal
air soft works great usually..
and the pitman.... crap, what truck fits that has the almost flat one... i can't remember. man i'm getting forgetful in my rip ole age of 20 lol
l8r, John
lol gonna cut my music short....with my angle grinder tomorrow
this is my first so hope mine dont fail
any idea how many oz ill need
well post it when you think of it you old bastard:thefinger:
Any TTB fullsize truck, they all run the same box as the ranger. I got mine from a late 80's F150.
