Gaskets?
footee
Kansas City, MO area
I had to pull my exhaust to drop my tranny for a clutch change. I didn't install new gaskets from the y pipe to manifolds. It does sound like it's leaking a little but will that cause a trouble code? I have a couple o2 censor codes, p1131 and p1151, didn't know if that could be caused by the missing gasket/leaks.
Shouldn't throw codes up but it's always best to have it sealed for winter can cause a back fire affect when shifting. Ifs a big leak
Sent from my SAMSUNG-SM-G870A using Tapatalk
The exhaust isn't going thru in a steady stream, but in pulses. In between pulses is low pressure which can suck in outside air throwing off the o2 sensor.
I ended up replacing both upstream o2 sensors and as it turns out, one was broken. I also installed a gasket downstream between the cats and tailpipe. I can't hear any exhaust leaks now. Parts store didn't show a gasket at the y-pipe to manifold so I'm assuming there isn't one there, correct? Due to the flare on the pipe...
