Speedwagon
- Apr 8, 2008
- 4.0 V6
- Automatic
'87 Ranger standard cab, long bed, 4x4 2.3L... the gas tank hangs down below the frame rails, which is not so good since I've banged it on some rocks because of this. Do the B2 tanks go in the back, between the frame rails? And if so, would it swap into the same space on my ranger? Assuming it will, which fuel pump setup would I need to use, or are they the same?
