I have a 1988 ford ranger, 2.9L V6 with a dual tank system. Right now the gauge somewhat works but its as if there is a gray zone berween the 1/4 and 3/4 fill lines that the gauge cant go over/under. When we tried testing the ground on the pump we found that it may be a grounding issue since the gauge worked and showed what seemed to be an accurate amount of gas on the gauge when we used a test light on it, however when we removed the test light it went back down to the 1/4 fill line when tank is nearly full.
Even with the apparent grounding issue the fuel pump works just fine so thats where I’m a little lost. We recently busted open and repaired the electrical on the tank seitch valve since the rebuilds were completely wrong for my fuel lines, but I don’t think that has anything to do with it since it was doing this same thing before.
Any ideas/advice is appreciated.
