I have a 1984 ford ranger xlt 4wd but i have no idea how big the gas tank is it says 30 but i dont quite belive that and it looks too big to be a 17 gallon help me out here
I have a 20 gallon in my 1997 4.0 4x4 SuperCab. my guess is you have a 15 gallon if it is an original equipment tank.I have a 1984 ford ranger xlt 4wd but i have no idea how big the gas tank is it says 30 but i dont quite belive that and it looks too big to be a 17 gallon help me out here
If you don't have two filler doors, you don't have two tanks unless the PO changed something. .I don’t think I have a second tank that’ll be cool to have one
Bronco II tank is indeed 23 gallons.The original second tank was made of steel and due to it's location, caught all crap flung up by the tires. So, unless you can find a southern vehicle with one, they are all rusted out and replacements are unobtainable. A few have used a Bronco II tank, which is bigger (23 gallons - I think). The potential issue with them is that they hang below the frame and could get damaged. Then there is the making a hole for the second filler neck, building a support structure for the tank after removing the spare tire carrier, and rigging up the electric, valving, and fuel lines. Not impossible but it would take some doing.
I wouldn't mind doing this but I would need to find a home for the spare. Probably along the lines of what Uncle Gump did for his spare. That I would need to rig up some kind of protective skid plate for the tank.
