- Oct 1, 2007
Hi to everyone on TRS,
I just wanted to write a quick FYI/Review of the Rough Country 4" Suspension Lift Kit I installed on my 92 Ranger STX 4.0L 4X4. I Have read some negative things posted by others across the internet about this lift. I just wanted to address these with some first hand experience. The first thing that often comes up is that the design of the passenger side axle pivot point drop bracket being of a plate design causes interference issues on the dana 35 front axle and could lead to possible diffy damage if used hard off-road. Well, as the bracket simply drops the factory mount down it keeps clearances the same as stock I cycled the suspension fully without the coils even installed and there was no clearance problems. The other issue I have seen although not as often is that some have mentioned problems with brackets not fitting properly. I had no such problems with my kit all brackets were shaped correctly and bolt holes lined up exactly. The hardest part of the whole job was removing the factory pitman arm from the steering box. All in all this lift seems to be a great value. I just wanted to write this so others on a budget wouldn't be scared into a more expensive kit just because of someone's bad experience.
