fuel system trouble shooting. has this happend to you?
1996DANGERRANGER
eaton township ohio
so i was driving to work and i was coming up to a red light so i pushed in my clutch and my truck died. well i found a blown 20amp fuse for my "fuel system" so i got another one put it in truck ran better than normal. i drove to the parts store with no issues at all and bought a spare fuse. i started backing up and the fuse blew. put the spare in and drove forward and wen i parked it blew again. bought another one and when my brother cam with the trailer i was going to pull up on the trailer and it died right away. anyone have an idea???
and thinking about it i seems it did it whenever i pushed in the clutch.
I would recommend checking all your wiring by your clutch pedal. It sounds like you have a bare wire that is grounding out. I have seen issues of this sort on some of the older class 8 trucks that I have worked on. If you can find it you should be able to repair the wire and then put something over the wire harness so that it will help prevent it from happening. Hope this helps.
Ray
