Fuel Pump Question
xxZestxx
Which relay is the fuel pump relay? Black Green or BRown?
The Fuel pump is not turning on, i havent got under it yet to drop the tank and check the power, i want to check the relay first, but there are 3 of them. can any one help me,,, Thanks
86
2.9 V6
Ford Ranger 4x4
On right front fender apron just between the map sensor and the self test connector. Just listen if you hear a "clic" from the relay when you start. i you hear a clic when you start then tell a friend to start the truck and hit the bottom of the gaz tank with a hammer just under the fuel pump. If the truck start, change your fuel pump
Never heard it click at all, i tested the wires only one of the 5 has volts on it. with the ket in the on position.
At the relay connector, you should a power(12 Volt positive): A red one, and a yellow one. If you have only one wire with power. Look at your fuse link first, you have probably one bad. You have some fuse link at the starte relay, and some more near the voltage regulator.
