LeeRozema
- Feb 25, 2013
So I have a 83 ranger that has a 4.0 swap. I'm having cold start problems. When the truck has sat for more then two hours it won't start unless I let the fuel pump prime tell it kicks off. Once it's stops priming the engine will start right up and run great. I've change the fuel filter and installed a inline check valve after the frame pump.
