ddjo
I replaced the fuel pump on my 01 Ranger 4x4 about 6 months ago and now it will not start. Replacement pump is a Delphi FG0873.
OBDII is showing the same code as before the replacement: P0232 (Fuel Pump Secondary Circuit High).
I expect the fuel pump to last longer than 6 months so I'm concerned there's an electrical issue that's causing the pump to burn out (i.e., always stay on).
Any ideas on how to test this theory?
Fuse looks fine and I've swapped relays to ensure the relay isn't the cause.
Inertia switch doesn't appear to have tripped either.
Thanks in advance!
Thanks in advance!
