After the 1998 change to Returnless the FPRs were not considered a separate part
Just included with a new Fuel Pump assembly
But on the 1998-2000 assemblies they are just hooked directly to the fuel pump and to the OUT to filter hose at the top of the assembly, then have a 3rd hose that goes to bottom of the tank to return fuel when 60psi is reached
You should be able to replace those if they are rated at 60psi
In this picture of assembly:
https://static.cargurus.com/images/site/2015/02/05/19/04/pic-2994795724152227059-1600x1200.jpeg
The round silver color unit is the FPR, its connected to the pump and out to filter line with rubber hoses and clamps
On its back side is a white "return" hose that peaks out at the left bottom of assembly
2001-2011 are different FPRs, just have 2 hoses connected
The 1998-2000 setup caused fuel pressure to fluctuate too much at the engine end
So in 2001 Ford added a 3 port fuel filter, 3rd port was a Return line back to the gas tank
This Return line connected to the FPR in the tank, same location different plumbing
So pump was connected directly to the filter's IN, no FPR in between
FPR maintained 60psi in the filter so less fluctuation at the engine end of fuel system
