Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
My truck is a returnless style as well, going to the part store they said they don't have one, I've found some that look exactly like it online but then it says it won't fit the truck and won't pull anything up for it other than aftermarket styles that are a remote locationThe V6 Rangers changed to a 60psi Returnless fuel system in 1998, so has the FPR in the gas tank with the pump
Not sure if the 4cyl Rangers did that until late 2001(2.3l Duratec engines)
If you have 2 Fuel lines in the engine bay, they have braided mesh steel coverings, then its still a Return system running 35psi fuel pressure
So has an FPR on the Return fuel hose mounted on the engine/fuel rail
Couldn't find a Ford/motorcraft part number specific to 1998-2001 2.5l Rangers
