smegun
looking at these dorman parts I want to replace from the pump to the filter anyone try these or should I use the metal type with rubber hose ?? need best path of enlightenment qui chang I most likely just need a section up by the connector..." thought it was a metal line" picked up a kink by the quick connect has me worried...rubber hose up my nose or use a hot hair dryer to mount the plastic type nylon connector ?? its a pretty deep fitting at the pump and the filter and that ridge to overcome not to mention the quick connector is a bugger to get off at times leaving you with a metal corrugated retainer in your hand ! the dormans must have a tool or similar action not sure details details its in the details two miles in is details detail later again
