Fuel Filler Tube alternate
librum
NOVA
This may be in the wrong section, but the movement and extension of the fuel gate is often done in high lifts, so stuck it here.
The 'fuel gate', #%27936, needs to be moved back towards the rear wheel. Not hard. But the fuel neck, #9034, is too short. Tube in tube? What do the 'high risers' use to extend the tube(s)? I am looking before I do the cut/move. :dunno:
How much longer do you need? I think the assembly is 3" longer for 93 up rangers, but don't know if it is the hose part that's longer or the metal neck piece. Maybe you could weld a piece of tubing onto the neck that the rubber clamps to?
The length is listed on the detail page at autozone here:
Older:
http://www.autozone.com/autozone/pa...N-iu3qbZ8vdfb?itemIdentifier=974183_0_0_40163
Newer:
http://www.autozone.com/autozone/pa...fZ8vdfb?itemIdentifier=210536_0_0_28892,40163
You can find them alot cheaper at amazon or ebay!!!
