front lift
chadmilliser
MOIRA NY ( 5 MILES AWAY FROM ) CANADA
I bought 2 inch lift shackels for the rear of my truck and was wondering what I can do to the frount to raise it a little. I wana maybe somday get a little body lift and new rims and tires. I just wana know a fast way to . I like buying my truck parts at homedepot! I hear you can add washers to the front spring . do you have to get it allinged after !! I just do not want my truck to look like it is noise driving . I do not see my tor keys on my truck
1995 ranger splash . does it have them !
Any ideas for cheap
I fount what i needed to know about lifting
however how much of a lift can I do before I have to alined !
The tops of my tires to my look like they sit in a little a garage once told me it was because of the i beams that ford uses .
the maximum you can lift the front without drop brackets is 2". any time you change the front ride height by any amount, you need to have the truck aligned.
dont go back to that shop for a alighment.......
yep a you can lift a avg of 2 inches(more if your springs are sagged out) before needing drop brackets or cut and turned beams for camber correction. 2inches and under you can use the camber bushings to get camber back in to spec.
