Front End Problems...again.
finally got around to my truck and lifted up the driver side tire and moved it side to side and it had a horrible amount of play and you could see the ball joint moving inside the pitman arm.then i moved it from top to bottom and it has about an inch of play so here soon i guess im gonna have to put all new ball joints and wheel bearings in it :sad:
yeah, if ya gonna tear down the front to replace the ball joints....may as well replace the bearings and U-Joints while your at it....
l8r, John
If it moves, replace it. As long as it's apart check the tie rod ends. No need to replace the u-joints unless they are bad. Have fun. Ball joints aren't tough, just a pain in the ass. Get or rent a good ball joint press. Cheap one's aren't that much less expensive and aren't worth the headaches. Most rental centers have them.
yeah do i need a tool to get the ball joints out and is there anyway to press the ball joints in without using a tool..i heard you can tighten the bolt down and them them in..not sure,need a little bit of a crash course on ball joints cuz ive never done them.
