TRanger03
- Nov 1, 2010
- Automatic
Just a quick question. My tire is slightly towed in at the top (drivers front). I've replaced the lower ball joint, tie rod end, new camber kit, and had a front end alignment done. I had the upper ball joint tested at a shop with that puller tool and its fine. We noticed that the upper A-arm has a little bump in it, and the paint on it is chipped. Comparing it to the passengers side, you can notice a slight difference. Could it be bent? and if so, could that cause the tire to slightly tow in at the top?
