Fresh Air Intake Grill Question
jeff2761
WV
Is there any way to remove the grill located in front of the windshield? I've got a leak in my cab and I need to see if there are leaves and "stuff" possibly clogging the drain and causing water to find it's way in. Thanks.
Spotweld bit and weld it back in.
To check for leaves in the cowl, remove the fenders and there is a drain on each side that sometimes clogges up.
Thanks to both of you. I'll remove the fenders first.
