I still say go for it...werent you going for a D30 swap anyways...now you have the free axle to do it. But if it is a LP axle then forget about it. I would go for coils myself but leaves will work fine too.
Rear D35 is garbage.
Front non-CAD D30 is OK but the ring/pinion starts to get weak in the deeper ratios.
The non-CAD D30s use the same joint as a TTB D35, it's a lot stronger than a D28.
get rid of the d35, and replace it with an 8.8 but lots of people are running d30's? what!?!
first of all, the 8.8 is a rear diff, where as the d35 on a ranger is front... they aren't interchangeable, and i don't actually know of one build running a d30, and you ask damn near anyone and they will say it's worth more as scrap steel than as a car part... not to mention the axle in the front of his truck is probably a d35 to begin with, and is bigger and stronger!
you must have read it wrong get rid of the jeep d35 and use a 8.8. and swap the d30 upfront.
There is plenty putting d30's in the front. here is just one that i found in less than 10secs.
http://therangerstation.com/forums/showthread.php?t=92330
how can i found out what year the jeep is? shes upside down in a pile of junk so getting the vin number wont be that easy
i wont be getting the rear axle anyways, its missing the yoke and the bearings and the pinion looks to be just falling out, so fawk that ill just run an 8.8. i was kinda hoping i could get a matching set of axles so i wouldnt have to buy gears though but maybe the front will have like 3.73s if im lucky enough. thats an easy gear to find for the 8.8.
the radius arms/control arms on the front diff are bent to **** cause the jeep was pushed up on top of the bile sideways an shit but i dont need the control arms anyways, ill be going leaf sprung for sure if i do the swap. the front axle is also missing a yoke but the pinion threads and bearing looks to be in ok shape. anyone got a spare yoke?
and i also noticed theres no cad on the axle, thank god. so im guessing its 95 and newer? also meaning bigger joints?
man, the way u are to vehicles a dana 30 is a joke, you should not even be considering it, it took me the first time i ever did it 2 hours to shorten a full width 44 (which u have better access to) all u need is a grinder, some time, a bfh a protractor and a welder. the place where the brake line mounts to on a 78-9 HP d44 is the same angle on both sides, so u use that as a point of reference to make it all line up when u put the end back on
the d28, in my opinion, is still better than the d30... if for nothing more than you won't beat on it as much because you didn't just put 2000$ into it, and now think it's bulletproof
the purpose of sas's is to make the drivetrain significantly stronger, and to add wheel travel to the front... the difference in strength from the d28 to d30 is negligible
a d28 and a dana 30 front axle arent in the same catagory. the 28 is junk and cant even take 31's. a stock d-30 can handle 33's-35's without much problems...
though i still dont suggest running one.
