- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
I also am jealous! Even as parts I think it;s worth it.
Good luck,
Richard
Good luck,
Richard
smaller turbos are better for 4x4, but for around here it shouldn't really matter either way, turbos aren't all that hard to swap anyway.
run that engine, it has the 8:1 compression forged pistons, the turbo sounds to be in good shape, I'd run it, I believe the Garret is better than the other anyway.
As for the internals, take the plugs out and put some oil in the cylinders, I'll assume it hasn't been rotated much, the oil should help break down any rust. When you get it up to running, these things are strange and have 120psi compression because of the low compression ratio so don't worry about it, it threw me off the first time I did a compression test on my engine until I remembered the ratio but they were all within a couple psi of 120...
One more thing, look at the part number on the exhaust manifold, if you are lucky it will start with E6 not E3... E6 was the good casting, mine came with the E3 and was cracked so I swapped on a E6
I'm not using one, runs fine for what I do, without the cooler just leave the boost controller connected, will limit the boost to 10psi which is I believe 180hp, makes my beast go pretty good... I have a stock TC intercooler and a plan to convert it to air to water at some point in the future, along with throwing the LA3 computer on there then disconnecting the boost controller
Oh, what's the code on the side of the computer that came with yours? If it's not one of the more desirable ones (HERE is a list o fall ford EEC IV ECM's) I have one I could trade you...
THIS PAGE has some useful info too
Also just read through Dave R's turbo swap page HERE and might have figured out my tach issue...
stock non intercooled is 155 hp....just as a reference, the turbo pinto i built for my dad totaly stock bottom end stock head, e6 manifold and t3 with pc1 ecu and small vam ran 13.10 at 110 in the 1/4....even the older ecus run good with a manual boost controler and good gas....
Good deal. I've picked two spare 2.3t motors over the years and really had planned on using one in my 89 4x4 but found a rolling 93 4.0 Explorer chassis with a D35 and 8.8 so going that direction. Especially since mine is a 2.9 and would require a lot more pieces. I have an 88 Turbocoupe and an 85 SVO and love the little engines. They are very durable if you keep detonation away. I keep thinking I need to find something to put one of them in. Lol
Will be watching for your swap and good luck. Does sound like a fun project!
this threads making me want to turbo swap a ranger and i already own a turbo coupe!!
my set up....messy wiring and all, swapping it into another ranger, going to be a lot cleaner the second time....i can't get traction on dry cement until about 3rd lol
I'd keep the car and buy a turbo setup/engine from another car!
