sjranger
Hey all,
I installed an arb in my D35 last week and did the external e-clip elim using the echo spring in the tech section. I am now getting an occasional metallic bang/thud from the diff area when taking roughish right hand corners only.
I tried all combinations of locked and unlocked hubs and diff as well as dropping the front driveshaft and I get the noise every time. The wheel bearings, ball joints, and wheel joints are newer and tight, as well as all the steering components. The poly bushings on the arms and beams are in good shape as are the springs and shocks.
I have it narrowed down to being the sound of the center axle shaft moving in and out of the pumpkin and I am hearing it 'bouncing' against the cross shaft in the locker. I have tried tightening and loosening the 'preload' on the echo spring using a machine collar on the shaft, and it seems to have gotten much better after tightening it up a bit.
For those of you who have done the clip elim, have you had noises like this?? Do you guys still run the cir-clip and washer in the passenger hub (retaining the stub shaft in the spindle)? I'd really like to get rid of this noise but I don't want to keep tightening up the spring and put the extra wear/strain on the cross shaft and locking hub.
