SuperDangerRangerXLT
- Jan 30, 2017
My FM132 transmission went out on my '90 Ranger, will an M5OD bolt straight up?
What is different about the floor? The floor of the cab itself or just the panel around the shifter?
If it is just the plate around the shifter I would get one from a JY to go with your trans.
Neither. Its the location of the shifter that really makes the difference. On my 88 the shifter of the M5OD still hits a bit at the front of the hole.It isn't an extensive modification, and may not be needed on a 90, but if it is its just a hammer mod.
Ok, I was thinking a '90 having the M5OD for an option shouldn't take a whole lot of work to make it fit.
