Flywheel/flywheel Bolts
Busterdude2
Washington
Currently gathering parts to do a manual swap into my truck. While going through what I have I found the flywheel bolts don't protrude past the back of the flywheel so there is no way they would bolt to the crank. Not sure if I have the wrong flywheel or the wrong bolts. As far as I have researched both are correct.
Flywheel: LUK LFW156
Bolts: ATP ZX-1026
Can anyone who confirm if either of these are the correct part?
How long are the bolts you have now? They're likely for an automatic transmission flex plate.
Apart from pulling some at a junkyard they are tough to find. Fastenal part number 11113398 should work.
https://www.fastenal.com/products/details/11113398
This post has the correct bolts pictured.
Can't find any part numbers, but here's a pic.
Flywheel bolts are M10x1.0 and about 45mm long
Pressure plate are M8x1.25 and about 15mm long with a lock washer
The bolts I have are M10-1.0 x 23mm. I will order those from fastenal. Thank you.
