flushing oil system
^ Yeah, it's funny I know, but there's a lot of stuff we can learn by paying attention to "folk" stories of things that have been done . . .
And I can't dispute that in many cases, they do work.
Given your post about ATF in a lawn mower's fuel supply, I would be tempted, and willing, to try it if my mower were in a similar conditon.
The topic of the original post, re: engine flushes using ATF - well, I guess that as with anything else, you have to run your own "question and answer":
1) Engine flushes - "yes?" or "no?"
2) Engine flushes using ATF as the flushing agent - "yes?" or "no?"
FWIW, my answers:
To 1): No, not at this point, because I change my oil and filter every 5,000 km/3,000 miles, and that's often enough that so far I don't see any need to.
If I were to flush my engine, though, I would be very careful to use some chemical that is meant as an engine flush.
To 2): No, never.
Best way is with a product called Auto-RX. I've used it.
You add a bottle to your oil if it's pretty fresh, otherwise change the oil and filter. Cheap stuff is okay to use.
Drive 1500 miles.
Change the oil and filter again, use whatever is on sale. Do not add Auto-RX.
Drive 1500 miles. This is when the dirt and crud really comes out.
Change the oil and filter with your usual brand and you're done.
www.auto-rx.com
I think I would be pretty scared to put ATF fluid or disel fuel into my crank case.
