wbhvacer
- May 17, 2018
- Automatic
I have been chasing a stalling issue with my 87 2.9 and read a thread some where that suggested to unplug the map sensor for the symptoms i have.
So with the map unplugged it will run and drive but misses like it is flooding , i have attached pics of the spark plugs all drivers side (1st picture) are carbon covered and all passenger side are clean(2nd picture) , So i now think i have a wiring issue to the driver side injector bank like a grounded wire for the ground for that bank causing constant fuel flow from those three injectors or the ecc is not switching the ground for that bank.just not sure how to proceed from here to test .
Ps i hooked up a vacuum gauge and with idling it stays in the green normal motor but fluctuates some, i assume the miss is caused by the carbon spark plugs.
