Flipping Axle Over Leaf Springs/Help
SykoRanger88
Purcellville VA
ok so i found out its not a good idea to pull a leaf spring to get a drop but i heard about flipping the axle over so its on top of the leaf springs instead of the bottom, as of right now what im doing to my truck is gonna give me a 2/2 drop(coils and fliped hangers) is flipping the axles over on top of leaf springs a bad idea? is it something i gotta buy alot of parts for and does anyone know how much a drop it will give me? if its more than 2inches im guessing that its gonna be too much since i would assume a 2/4 would bring my truck to a level position, thanks guys
A flip kit is the safest route when dropping the rear, you will need to order a flip kit, which basically, is a u-shaped mount for the axles to sit on and new u-bolts. In total it should give you anywere from 3-6 inches of drop, depending on what tires you have an the condition of your springs. And for cost, I've hear from 30-69 bucks, depending if you buy them from ebay or a specialized manufacturer. Hope this helps ya man, im droppin my 97 and having the same "fun" time lol
oohh ok thanks man i think im gonna just do a hanger flip then, cuz 2 inches along with 3-6 in the back is gonna be way to much lol it would be dragging the bumper maybe later on when i lower the front more i will do the flip, thanks.
The axel is only 3" wide therefore it will only give you a 3" drop with a flip kit. Rangers sit higher in the back anyways so with the kit it would put you level. S-10 come stock with axel over leaf rear suspension so there isnt anything to worry about as far as safety. I would deff. get the flip kit for the fact that once you lower it i will want to go lower. I would just heat the front coils to get it lower rather than buying a $100 set of springs.
Btw in order to drag the bumper you would have to do A LOT more than a 4" or 5" drop. Not to mention you would need to to notch the frame. Hope this helps
ok cool but my question is i wouldnt do both flipping the hangers and flipping the axle then? i would wanna choose one or the other? flipping hangers 2in and fipping axle 3 inches,one of those would be my choices? because im saying otherwise its gonna be like a 2/5 drop lol, thanks
btw if any1 can point me in a good direction of where to buy the flip kits that would be sweet.
Almost right, but not quite!
You also have to take into account the width of the spring pack. If your spring pack is 3" thick, flipping the axle will give you a 6" drop.
My 91 ended up 7" lower in the back after flipping the axle. I had to do a c-notch to get some suspension back, & install some cut Splash coils up front to bring the front down to match!:icon_thumby:
Trev
ok thanks man this is out of the question then cuz my front is only getting a 2in drop lol, plus i still haul atvs and stuff with this truck, seems like just flipping the axle alone is to much a drop for what i need specially if i have to modify stuff to make it work right. i guess ima flip the hangers and leave it at that, thanks guys
never heat the front springs, it changes the springs properties and takes the "springy-ness out of the springs, you would be safer cutting them(or buying drop coils,but im poor lol) but only half a coil at a time, thats what i did, then you get the adjustable camber bushings, and there easy to install, then get an alignment....and viola!
definitely, if i had the $$$ I would go buy some dream beams, but i dont have a "high income" so i havta deal with it for now.....ahhh economy....lol
See, now ain't you glad you talked it over:headbang:---put some before-in between--after pics on here so it can be viewed by others who might do a similar drop:icon_thumby:
yea i know how that is im goin through same crap, ill deff post some pics up when its all done, before and after
Couldn't you also just get an Explorer rear end? I mean, 4x4 and 2x4 off road guys get them because they are stronger (31 spline axle shafts) and cut the spring perches off to weld new ones on the top because the Explorer has the axle over spring setup like what you want to do, vs the spring over axle setup the other guys want. So if you were to get an Explorer axle it would bolt right in the way you want without having to buy a kit. Explorer axle left alone and put in a Ranger would equal a stock drop I would think.
I'm wanting to drop my Ranger 2/4 using coils and an axle flip using an Explorer axle.
I can get the Explorer axle at pick-n-pull for $127. Now this will hurt, but I'm going to think a second... an Explorer axle will have the spring mounts I need to mount the axle on top of the leafs, which means I don't have to spend $60 for a flip kit.
$127 - $60 = $67. This means for $67, I upgrade to an 8.8" rear with trac-loc and disc brakes. Sounds like a good deal to me.
dont for get the shock mount on the explorer arent in the right place if im not mistaken
