do i need to snag an 80 amp continous relay or is it already in my stock setup? And should I switch the neg switches or run the stock ones?
Is there a black wire leading off the thermostat? If so you should be able to put a relay between that and the ground to control everything instead of the big 80 amp
Do you not worry about over cooling? I know some vehicles won't run properly unless they hit that certain temp.
I'm going to answer the original question, yes the Flex-a-lite fans are excellent. The controller is adjustable so I can set turn on temp, it has an AC relay built into the controller so the fan is on when ever the AC is on.
My Flex-a-lite 40 is a direct bolt in for the Ranger, mine is 6 years old and it works perfectly
Taurus fan did wonders on my closed cooling jeep Cherokee, and it was cheap to boot. Correct, the 4x4 guys love them. No experience w flexalite
Sent from my DROID RAZR HD
