Byronator
I am looking to replace my cylinder heads on my 1999 3.0L v6 flex fuel. I found an ad of FB for some parts from a 2006 3.0L. I was wondering if this would be an exact fit. I know the v6 vulcan engine was used in both, but knowing how ford changes the smallest things on the same model vehicle, I wanted to get a second opinion. I actually just need to replace my valves because I currently have a misfire and I have decided/diagnosed it to be the valves. But I'd rather just replace the whole head with valves and everything already assembled and ready to go instead of taking all the valves out and putting all that back together again. I also damaged two holes where the valve cover bolts down on one of the heads when I replaced the valve cover gaskets recently. So I kinda have another reason to replace the whole head.
