Finally put in my spacers.
Shawn_248
Lexington SC
Install went pretty good, except the coil springs were a PITA to mess with. Getting an alignment in the mornin. Only issue I have is a clunk in the front when I mash the brakes. I double checked and everything's tight, so idk wat it is. I guess I shouldnt worry about it too much
let me know how the alignment goes i got some spacers lying around been thinking about putting in. i put some leveling coils in a little while ago, didnt lift any:( , and have a clunk too.
I'll let you know, pretty sure i'm gona hafta get the aftermarket camber kit
Yes you will. Had to get it with mine too. and yeah, the coils are a pain without a coil spring compressor
How much did you pay for the aftermarket kit and alignment? Also, do you have the clunking noise I mentioned. Everythings tight, so I was just wonderin. Wana make sure I did't do anything wrong
No, they're made from "delrin" but they felt like a VERY hard plastic
cool. i dunno if i trust then in the extreme cold though... but ive had bad experiances with plastic so i like to stick with steel
________
Latina Cams
I dont remember exactly but i know it was more expensive than i thought. and i didnt notice any clunking noise
My tires are \\ //. I know I'm gona need the kit to fully correct it, but money is VERY tight right now. Do you think that they could get it pretty close without the camber kit?
so much better when it looks level...gj dude!
Great looking truck.... but I have the same spacers and the shop charged me 120 $ for alignment and aftermarket kit... its not actually aftermarket its just got more adjustment..than stock.. and a different shop charged my buddy 135 for the same alignment on his ranger with his kit.. so it will probaly be between 120 140
if you go get the camber adjuster from napa for 15 bux and put them in, be a $50 alignmment instead.
