Master cylinder and pushrod installed. It wasn't as bad as I thought it might be, but some of that is because I moved the power distribution box, and some of the tools I have. Getting the master twisted in correctly is a matter of getting it lined up the right way first, and having the room around it under the hood to twist it by hand....from the outside.
The hardest part for me was getting the pushrod in and locked (above). I slipped it on to the peddle and used the peddle to lock the pushrod into the master cylinder. The difficult part was getting the pushrod ALL the way on to its locking point. Because of the large harness in the way, it was hard to get the pushrod off and then back on again. I got it on, but couldn't apply the force necessary to lock it in place.
Fortunately, I have these. I'd always wanted a pair, but only finally bought some when doing the engine/trans swap in my Integra. Had to have them. These are made by Crescent and when I purchased them, the only place I could find them (2 years ago) was in England. So I ordered them. I don't use them very often, but when you need them, you're really glad you've got'em.
Getting the boot in place was mostly done applying pressure from under the hood. There was a harness that runs around the side and down by the brake system. It has to be moved out of the way to push in the boot....might be different on other Rangers. Then finishing up setting the boot in from inside. I used these tools to do that.
All and all, this wasn't as hard as I thought it would be, but I think what made the difference was my long needles nose pliers and moving the power distribution box.
I still have the clutch switch to put back, but the new version's "retainer" cap is much easier to deal with then the one that was on there. I had already put the other end of the hydraulic line in around the frame to where it goes. I did that first. I still have a line anchor to push back into the frame down there, but that's all.
